FIAT Auto Specialist Team
Thread Tools
Old 24-06-2009   #1
Unhappy 1.9 JTD turns but wont start
Folks, hope you can help.
2003 JTD ran without issue, parked up overnight and now it turns over but wont fire.
Iv checked and have fuel to the injectors.
From looking at the key, there is no immobilisor fitted.
Iv got the battery fully charged. Hot or cold, there is no signs of ignition at all.
Previously the glow plugs were only on 3-4 second to produce faultless starts.
The glow plug dash light stays on steady until off, appearing to operate correctly.
Thats about all i have on the fault.
Also i dont have a manual but what is the dash light that looks simiular to a door or window??
Any ideas please......
gs1100hardtail is offline Reply With Quote Quote
Old 25-06-2009   #2
Re: 1.9 JTD turns but wont start
A 2003 should have the standard fiat imobiliser.
Do you have a blue key? near the base of the metal part there should be a little number '2'. This indicates the car has fiat code 2 imobiliser.
Thanks gs1100hardtail thanked for this post
Mdeko is offline Reply With Quote Quote
Old 26-06-2009   #3
just can't get enough
toad101's Avatar
toad101 has donated!
03 jtd's have immobilisers
it won't be the glow plugs at fault, their not needed this time of year
when you turn the ignition on can you hear the fuel pump?
toad101 is offline Reply With Quote Quote
Old 26-06-2009   #4
Same happen to me
If you read my old post same problem
It turned out to be a faulty injector
Pat McCoy is offline Reply With Quote Quote
Old 26-06-2009   #5
Here to help
bridges's Avatar
bridges has donated!
Quote Originally Posted by gs1100hardtail View Post
Im more used to working on the Peugeot engines, however.
Where did you check the fuel. it might have had pressure but it needs a fair bit for the injector to electronically open.
Be careful do not check by removing an injector we are talking risk of death as diesel injectors on jtds operate at serious psi
The injector is controlled partly via a cam sensor and a crank sensor. you can have diesel all the way to the injector but it wont be put it in the engine if these are at fault. also in the rail there should be a pressure sensor which will only allow the injector to fire at the correct pressure.
Ink Black Coupe,
Koni susp' kit, Strut/Subframe bars. Camber bolts, 3g Discs, Yellow pads. Ram air, S.I.P, FMIC, Superspool turbo, Aquamist, Full S/S decat exhaust. Hid's, Le kit and Tan leather.
Alfa 156 16v Jtd-m Ti 150bhp
http://i54.photobucket.com/albums/g1...2006/alfa1.jpg
bridges is offline Reply With Quote Quote
Old 26-06-2009   #6
Thanks all who made suggestions.
Mdeko, it was the key at fault. I tried the spare and the car started fine. I did not realise there was an immobiliser or i would have checked this prior.
Every days a school day eh.
Is it normal for these keys to lose their code??, i will check on here as im sure someone else must have experienced this.
Thanks again
Thread Tools
(T) 04 2.0 JTD Auto wont start! pinkystimp Ulysse 18 04-06-2009 13:30
(G) Ducato 2.8 jtd wont start Ducato man Ducato 3 13-01-2009 13:50
(G) mk2 punto 1.9 JTD wont start help!!! densadie Punto (Mk2/2b) 1 21-03-2008 19:10
(T) Punto JTD 1.9 2001 WONT START densadie Punto (Mk2/2b) 1 18-03-2008 23:39
(T) multipla 1.9 JTD wont start bikes-for-me Multipla 5 09-10-2007 19:08
