need to change my front fog light bulb, do i need to jack it up to change it??
:bang: and before you ask yes it is foggy often up here in scoltand i dont drive about in the clear whether with them on
Ok, haynes manual says there is a hatch in the wheel arch, remove that and you can detach the wiring. The light is then attached by one screw above the light at the front and two below the light access from the back.
