Redpunto2004
- Nov 11, 2004
- 7
- 2
Right, In the process of changing the radius arm, I've had to dissassemble the brake drum, now I have a problem. When I went to put the drum back together, the drum wont go on. The shoes are as close together (top end just touching the piston, bottom end touching the thing at the bottom) as possible but the drum just doesnt fit over the shoes. Anyone had this problem? Anyone know how to solve it? Also, the haynes manual says don't press the brake with the drum removed, but I thought I would give it ago to see if i had assembled the brakes properly, and they worked but when the pedal got all the way down, brake fluid started spraying out of the brake cylinder, now is this happening because its broken, or is it happening simply because the pistons are coming out so far because the shoes aren't stopping on the drum (which isnt on) and there is a gap for the fluid to get out?
Anyone with ideas????
Thanks.
Thanks.
