Is it possible to disable the key coding from the Engine management system? Reason behind this question is, I have a HGT with only 1 key, tried to get a replacement from Fiat but somehow the code that matches my chassis number doesn't fit my car, their only solution is to spend £300 on a new lock set! As I see it even if I do this what's to stop Fiat making an other mistake and my, and presumably someone else’s keycode being wrong again. I could get a key cut just to open the locks, but wouldn't start the car or deactivate the alarm. I am wanting replace the Fiat system with a separate Thatcham alarm, is this possible?
