im Axle Specialists
Thread Tools
Old 12-05-2009   #1
Cleaning the Punto ICV
Hello all I'm afraid I have a couple of simple questions :-) My punto is juddering when idling and after reading some articles on here, I've decided to try cleaning the inlet control valve to see if that helps. However, I'm relatively new to this (though quite technically minded) so I just want to make sure I'm not going to do anything stupid:
1) Can I confirm that the throttle is circled in the pictures below:
2) Do you have any suggestions on how I might go about removing circlips like these:
Do I need a special tool? Will I need to cut it off and replace it with a jubilee clip?
Thanks in advance!
Steve
Thanks Neil75 thanked for this post
Stevil Knevil is offline Reply With Quote Quote
Old 12-05-2009   #2
Re: Cleaning the Punto ICV
the clip fingy i used a flat head screwdriver under the groove and push....be carefull as i slipped a few times and cut maself
ozz2009 is offline Reply With Quote Quote
Old 12-05-2009   #3
As for the clips, as said just attatck them with a screwdriver or pliers to break them off. Then use normal jubilee clips to replace them.
Mdeko is offline Reply With Quote Quote
Old 12-05-2009   #4
mzhussein has donated!
use angled pliars and you can unclip em and re-use em
but easier for next time to replace with jubilee, dont know about icv...mines a mk1...but a toothbrucsh is a good tol on hand!
mzhussein is offline Reply With Quote Quote
Thread Tools
(T) Icv scoobie2711 Bravo / Brava 2 21-11-2008 14:53
(G) cleaning my injectors on my punto 1.2 16v PUNTOELXBERTONE Punto (Mk2/2b) 4 22-06-2008 18:58
(T) ICV problem ledo Bravo / Brava 3 12-05-2008 10:36
(T) ICV question? ian grant Cinquecento / Seicento 5 27-04-2008 14:10
