Stevil Knevil
- May 12, 2009
- 4
- 3
Hello all I'm afraid I have a couple of simple questions My punto is juddering when idling and after reading some articles on here, I've decided to try cleaning the inlet control valve to see if that helps. However, I'm relatively new to this (though quite technically minded) so I just want to make sure I'm not going to do anything stupid:
1) Can I confirm that the throttle is circled in the pictures below:
2) Do you have any suggestions on how I might go about removing circlips like these:
Do I need a special tool? Will I need to cut it off and replace it with a jubilee clip?
Thanks in advance!
Steve
Thanks in advance!
Steve
