mattpunto18
Member
what primer can i use?
anything on ebay that i can get hold of?
does it matter what colour primer it is?
thanks
thanks
you want to use plastic primer,an it depends what colour your spraying the handles,try to get the same colour primer as your spray paint(it wont be the same colour just get as close as possible)dont forget to thank me if i've helped.what primer can i use?
thanks
:yeahthat:i'd use halfordsi used halfords gray primer(4 coats) and gloss spray paint(4 coats) . done the job just fine .
dont forget the laquer(clear)
so like after the third coat leave 15 mins then they should be ready to use?
