I have a mk2 1.2 8v 2002 punto. I have noticed recently a bit of difficulty changing from 1st to 2nd gear, the others seem fine. When i change up it feels a bit crunchy in the gearstick although i can't hear it crunching it also sometimes require a bit more effort to change gear. I have noticed that if i depress the clutch so my foot is really flat on the floor and hold it there for a moment or two longer than usual then this doesn't happen. Is this normal/the clutch/gearbox?
Also with the engining off and door open you can hear a creaky/clicky sound when depressing the clutch, is this normal? If not what is it?
I don't seem to have lost any brake fluid btw.
Any advice appreciated, cheers
