Hi all.. new to the forum
My girlfriend bought a Y Punto 1.2 8v ELX (all I know as there is no handbook). Since then the car has developed a few problems.
1. after driving the car home the speedo stopped registering speed.. The dash has power and all the dials and gauges work. I dont believe the speedo itself to be the problem as the needle lifts from its rest when the ignition is turned. Also the digital display in the centre flashes repeatedly with ignition on and does not register mileage... am I right to assume a "Speed Sensor" is the problem.
2. Today after driving maybe 40 miles and using a tomtom for a speedo the power steering packed up. The red light on the dash came on and obviously the steering is very heavy.
3. There is a fairly quiet but very high pitched "squealing" type noise coming from somewhere under the bonnet only when the engine is running.. I was thinking water pump alternator.... maybe a bearing on one of those.. just a guess
Any help or ideas would be greatly appreciated. Getting work done would not be a problem as a school friend is a ford technician.. just looking for some guidance as he is not too familiar with fiats
P.S. I have checked all fuses and unplugged and re-seated the plugs on the fuseboard
EDIT - Could the first two problems be related as i'm guessing the power steering system works differently depending what speed you're travelling at
