Thread Tools
Old 13-04-2009   #1
Albania
transmission shifter ?
Hii
I'm having some problems with my transmission shifter i think..it goes so hard everytime i change the speeds..a guy told me that i have to put some oil in there and will make it move easier (see pic ) , but im not sure i thought it will be better to ask somebody in here before i make a move...
ArberMehmeti is offline Reply With Quote Quote
Old 14-04-2009   #2
Albania
Re: transmission shifter ?
Anyone ?
Old 14-04-2009   #3
Stick your own title
mrcinquecento's Avatar
mrcinquecento has donated!
i would lean more to your clutch playing up tbh, and not disengaging properly.
Thanks ArberMehmeti thanked for this post
www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier
98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi
mrcinquecento is offline Reply With Quote Quote
Old 14-04-2009   #4
Albania
Old 14-04-2009   #5
Albania
anybody else got any idea ?
Old 19-04-2009   #6
Albania
im surprised how nobody was able to give me an advice or a answer
Old 19-04-2009   #7
Ireland
similar thing started happening to mine a time back, ended up having to get a new gearbox after it eventually started knocking. that was the first symtom i noticed.
black mk2 punto, HIDs, standard sub, limo tint, sony headunit..........awesome
bazery is offline Reply With Quote Quote
Old 20-04-2009   #8
Trader Rating: 6
Unlikely that ball joint needs greased and very unlikely to be your problem.
If it's tight getting into gear try greasing the 2 linkages under the bonnet.
If the gearbox oil hasn't been changed in the last 4 years, do it. People often overlook it.
If they don't solve the problem then it could be clutch or worn synchros i.e. new gearbox time.
Need alloy wheel spacers or bolts? PM me!
richie.guy is offline Reply With Quote Quote
Old 20-04-2009   #9
Albania
Quote Originally Posted by richie.guy View Post
i bought the car 8 months ago so i dont really know if the gearbox oil was changed .. can u plz tell me how to do that..and is there special oil just for gearbox ? or any oil can do ?
Old 20-04-2009   #10
Trader Rating: 6
Quote Originally Posted by ArberMehmeti View Post
Go to fiat and buy the correct gearbox oil.
Drain from the back, it has a plug like on the sump only smaller.
Re-fill with 2 litres at the top. There's a platic grommet covering the fill point behind the battery tray.
Linkages look in the engine bay for them, pull the rubber boots to one side and smear copper grease on them. Re-cover with the boot, change gear a few times and see how it goes.
Old 20-04-2009   #11
Albania
thanks for your information . i hope im not asking to much but a pic would help alot
Old 20-04-2009   #12
Trader Rating: 6
Linkages and fill point with grommet in:
Thread Tools
(T) short shifter brummy cinq man Cinquecento / Seicento 16 06-09-2007 17:35
Shifter fell off !!! HELP !!! dkirchoff Bodyshop 0 14-08-2007 00:37
(T) Short Shifter Cinq? JimCinq Cinquecento / Seicento 16 21-08-2006 23:55
(G) Short Shifter? six6six Punto (Mk2/2b) 2 30-05-2005 00:37
(G) Sloppy shifter!!! smokeme Panda (Classic) 11 04-07-2004 21:35
