Technical Punto Mk2 JTD, dashclocks problem.
lordlucan
Dudley
Hi all,
Recently removed clocks cluster resolving an issue with abs illumination. (some kind person had covered the illumination tubes behind the blind disc for city mode, handbrake, foglight and abs with insulation tape for no good reason as all worked fine !) That dealt with, i have struggled to reinstate the clock needles for temp gauge and fuel level indicator with success, tacho and speedo working fine. It appears that once the needles are pushed on the spindles from the cicuit board, they lean over from central position and seem to waver of their own accord.
Any help or suggestions (polite one's only please) with the above would be appreciated. Thanks :confused:.
