im halfway through doing my clutch, but ive snapped one of my gear cables, its the one with the adjustable end, how much and where can i get one of these? also are the hard to do. i dont have a ramp im doing ll the work on the floor.
hi there they are only about 50 quid for a new one from fiat but it might not be broken the earlier cables had an insert pice that could be removed if it is this type u can pull back and twist the end of the cable where the spring is then locate the pice back in i have a set of cables i can put on ebay if u want for 30 posted for the both any way as for fitting its not that hard u need the car jacked up there is a white cover above the exhaust that u need to remove and the cables connect under there u need to remove the horse shoe clip and take the socket of the ball joint then it should be free to be pulled back through if u want any more advise or them cables putting on ebay then just pm me
Price wise they maybe cheaper for an 8v, the price I was given was for an HGT and it was a couple of years back. They come in one piece from the base of the gearstick to the top of the box.
