Technical Punto Mk2b 1.4 16v sporting
Glasgow
Hey peeps,
Am just woundering are there any possible brake upgrades for the punto mk2b 1.4 sporting??
Like the cinq they have the punto GT front caliper as a direct swap upgrade.
IS there something like this for the puntos mk2b 1.4 sporting?
Ming
GT brakes will fit. HGT's should also fit but some say they don't.
When I measured up they looked like they would though.
front
Alfa Romeo
Alfa 145/146 1.6 3/97 onwards
Alfa 155 1.8-2.0 8v - TD 92 onwards
Alfa 145/146 1.7
Fiat
Punto GT 6/97 onwards
Brava/Bravo 1.8/1.9 D/TD
Barchetta 3/97 onwards
Tipo 2.0 ie 93 onwards
Tempra 2.0 ie/1.9TD 90 onwards
Punto GT up to 6/97
Barchetta up to 3/97
Lancia
Dedra 2.0ie 89 onwards
yes all are same
not sure if the gt being different or not is true either
edit hold on i may be lieing, i think the 1.4 sporting should already have that size an vented
edit no not to sure now this doing my nut in. need more books :eek:
edit yes looks like you do already have same size n vented as all them above :)
The list dave put up are 247 vented.
1.4 16v's are 240 vented.
that strage as people are selling all the list an the 1.4 16v with same part numbers :confused:
Well I'm 100% sure GT/HGT/Bravo/Brave discs are 247mm as I've owned them in the past, and I'm 99% sure 1.4 16v's are 240mm as I have a set of them too.
1.2 16v's are 247mm solid and 1.2 8v's are 240mm solid iirc
eper DVD Rel.20 is showing same part numbers too :confused:
For what Dave?
I just got a set of 240 vented off a 1.4 so unless there was a change at some point I don't know why they're listed as the same.
