PRINCE ROMEO
I have psyched myself up and i'm going to change my water pump/coolant pump myself, I know what and how to change the water pump and yes I am going to use a RTV liquid gasket when I replace it. But what i'm most worried about is the timing belt i've heard it has to go on in a very specific way im going to buy a new one I don't know if that makes any difference also while the timing belt is out i'm going to replace my crank seal as i think that could be contributing to my oil leak, also does anyone know why I might get an oil leak from the left side of the sump (the left side from when your under the car) I know if its from the right its likely to be a crank seal, I have already replaced the rocker cover gasket and my thermostat and I have used my gasket sealer on both so as to stop/reduce any oil leak from the top.
Also if anyone could get me some pictures as to the specific location of the crank seal I would be very gratefull, I know roughly where it is I don't specifically know any pictures would be great.
Also how do I tighten and loosen my timing belt, and does anyone know how or where I can get the timing covers as I have part of the housing but not all of it and it rattles like mad, actually how important is it that I have the housing for it.
