help, i have a punto gt3 a s reg, i have changed the plugs,leads, coil pack, i have had it compression tested, and it still continues 2 misfire and cut out when i dip the clutch, and ideas??
MAF meter or possibly a vac leak. Check all your boost hoses and vac hoses for leaks first, if all ok, check the MAF.
You can try disconnecting the electrical connection to it and see if that effects running. Also check the thin wire inside to see if it is still intact.
