Dave-G
Hi all.
My mk1 punto 1997 65sx has developed a few problems which hopefully someone can help me with.
The oil warning light flickers on at tickover speed, allthough it goes out as soon as I touch the gas pedal, the car has done 70,000 miles.
The battery warning light is now staying on permanently after coming on the other day, but going off after a short time.
My battery reads 11.08-volts with engine off & then drops to 10.5-volts with the engine running.
Revving up the engine does not change that reading at all, turning on the headlights drops the batterys voltage even lower & again revving the engine makes no change.
I know that this problem has got to be the alternator, but before I replace it does anyone know what wires, etc, could be worth checking over.
One other thing, at the front of the engine bay there is a canister attached to the engine mounting next to the timing belt cover. It has a brake line going into it & a blue tube which goes into the brake master cylinder, it has wires attached to what looks like a solenoid on the top of the canister.
I'm just curious what this thing does, I've never came across on any of my previous Fiats.
