Old 23-02-2009   #1
punto hgt - rattling noise from drivers side front arch? i think1
My punt has been lowered 50mm for about 6 month now and has developed a rattling noise. it sounds like a metal hitting metal type rattle, only does this over bumps or when going really slow like in traffic. but in slow traffic it sounds more like a slight grinding noise coming from the front and back drivers side. any ideas???? im puzzled.
g8crasher is offline Reply With Quote Quote
Old 17-10-2009   #2
easyrider81 has donated!
Re: punto hgt - rattling noise from drivers side front arch? i think1
Did you ever find out the problem/cause of the rattling as this sounds v. similar to a noise i'm getting on my HGT.
easyrider81 is offline Reply With Quote Quote
Old 17-10-2009   #3
Dark_Crusader has donated!
Recoil Champion
Have you examined underneath the car from a visual perspective?
It may reveal scuffing or scratching (or worse) which you can't tell from top-side...
Dark_Crusader is offline Reply With Quote Quote
Old 20-10-2009   #4
Quote Originally Posted by Dark_Crusader View Post
After removing and refitting my exhaust front end it's now makes a din on some curves especially road islands. Nothing else was touched on the chassis so I suspect the exhaust is rubbing somewhere.
DaveMcT is offline Reply With Quote Quote
Old 20-10-2009   #5
Recoil Champion
Quote Originally Posted by WhiteSei View Post
Mine did that for a little while WhiteSei when I replaced the back-box, it turned out I had'nt pushed the box up the pipe far enough causing the box to clunk against the rear of the car I also changed the rubber mounts as they looked a bit tired and it has more or less cured it unless of course I decide to take off like an F1-fighter Jet then I might get a clunk...
Old 21-10-2009   #6
I only undid the 2 bolts on the back of the centre cat and the at the manifold. But the rubber hangers did look a bit iffy. Its not that bad so I'll suss it eventually.
The metallic clanging might be the brake shield. I cant say about Fiats, but on one car I once forgot to bolt mine back after doing a wheel bearing.
Only option is to take off the wheel and have a look.
Just thought - how about the aircon condeser pot hehind the drivers side front bumper. The bracket on mine was quite rusty. Not enough to matter and its now waxoyled but I guess it could rust through.
(T) scratchy noise (drivers side front wheel) clairesicklefiat Punto (Mk2/2b) 10 24-11-2005 16:39
(T) noise from front drivers side brakes Lemzip Punto (Mk2/2b) 3 04-10-2004 21:33
(T) flapping noise on front drivers side of car broadfield Punto (Mk2/2b) 5 07-11-2003 19:00
(G) flapping noise on front drivers side of car broadfield Punto (Mk2/2b) 13 05-11-2003 21:29
