Caravadossi
Established member
- Mar 12, 2005
- 1,510
- 249
Number 1 was mixed fuel. I filled up when the tank was nearly empty with V-Shell.
2 and 3 were using V-Shell.
Yes your right about the 38.80L bit.
By the way, I reset the trip computer? to zero when the fuel is halfway (measuring it on a flat road) and mark it down on a computer program. Thats the way I measure the fuel.
2009/04/15 21:20
Your readings suggest you’ve improved your mpg from around 37mpg to 44mpg – but I’d argue there’s not enough data to be accurate. As you say, your first reading is a mix (95RON & V-Shell) – so we don’t really know what mpg you were getting on 95RON.
We would need something like 6 readings on purely 95RON fuel to get some degree of accuracy. For example, my last six mpg figures for my ‘54 Mk2B (1.2/8v) on 95RON (Conoco/ASDA) just prior to sale in Jun 08 were: 58, 39, 66, 54, 50, & 54 – which illustrates that one lone reading may not be reliable. My last six mpg figures for my current ’56 GP (1.2/8v) – same engine, heavier car - on the same fuel are: 51, 48, 45, 50, 53 & 51. (The readings are not trip computer based – but calc. from brim2brim … on [fuel low] warning absolutely filled to capacity until pump nozzle shuts off).
Similarly we’d need several readings on purely V-Shell to iron out any inaccuracies. Will you continue to record your data … 4, 5, 6? But say you do, we’re still unable to accurately measure any improvement given we only have one mixed fill to measure against.
I tend not (up until now) to use the [trip] much on my GP – but I do zero it at a brim-up & check the range read-out … usually shows around 500 miles. I also sometimes leave it on showing av.mpg or mpg just out of interest.
The cross-over issue (qisback) is one I’ve not heard before. I did talk with a Conoco tanker driver about a month back & he claimed that all refinery fuel (petrol & diesel) flowed thro the same pipelines. He said the practice of the tanker driver in-putting the additives at the point-of-sale (from the tanker) was history - & that now all petrol was the same 95RON until receiving the additives. He also claimed that higher octane petrol was still 95RON based petrol with more additives. If I recall his figures correctly – I believe he said his tanker took 33K litres of 95RON with 15 litres of additives.
