SuckMyGuts
My clutch on my punto keeps kinda going ....cant select gear very well at all.
so i got the slave cylinder off pushed in the piston my pedle was flat ont he ground by this time so that flicked up. got a friend to push down on the pedle slowly the piston in the slave cylinder was moving out nice.
anyways put it all back together tested my clutch out throught the gear box, then went out for a spin and seemed to be working fine.
after a week it started becoming hard to select gear again then did the same as last time. so i made sure no fluid was coming out checking or patches and levle. that was all OK!
so i guss its the master clyinder....
what do you guys think?
is it a easy job?
not had the best luck with this car.
1 year NEW..
gearbox
bottom end pully
power stearing motor
heaters keep stoping (BTW kick the passanger side foot well and it will kick in again)
rear drums
clutch
list gos on
let me know what you think about my master clyinder problem
is it a easy job?
1 year NEW..
gearbox
bottom end pully
rear drums
clutch
list gos on
