Old 13-01-2009   #1
pezzaspunto has donated!
Exclamation Suspension clamps?
hi just wondered if anyone had used suspension clamps and if they are any good? are they safe to use?
pezzaspunto is offline Reply With Quote Quote
Old 14-01-2009   #2
sdb-punto's evil twin
1383matt's Avatar
1383matt has donated!
Re: Suspension clamps?
get some off ebay, theyre crap but they hold out long enought to change all 4. just make sure someone holds the clamp while you tighten it so it stays straight and tighten them evenly, same when un-doing them. it really hurts your shins when they come off.
1383matt is offline Reply With Quote Quote
Old 14-01-2009   #3
Angel:Mum of the *****
Ninja59's Avatar
Ninja59 has donated!
cheap and rubbish alternative to lower a car do it properly most people on here think they are quite dangerous there was a thread sometime ago about these if you want more info use the search function
"59" MX-5 MK3.5 owner.
Ninja59 is offline Reply With Quote Quote
Old 14-01-2009   #4
MikeSalt has donated!
What do you mean by suspension clamps? Normally, I would think of coil compressors, such as those that Matt describes, which are used to change shock springs on McPherson style struts. They usually come in pairs, but you have to be careful to keep them directly opposite to each other on the spring. I did have one slip round, but there was no sudden release. I just had to slacken them off a bit and reposition.
The other possibility are those suggested by Ninja, clamps you permanently install to lower the car. These are not recommended since they apply a permanent force to a relatively small length of the coil. With plenty of driving, the springs will be considerably weakened.
MikeSalt is offline Reply With Quote Quote
Cleaning Battery Clamps/Terminal Thomas_Si Car Care 10 02-01-2014 14:59
(G) coil spring clamps? not a good cheap way of lowering! mrcinquecento Cinquecento / Seicento 5 04-09-2008 17:36
DVLA clamps untaxed cars faster4_tec Leisure Lounge 16 01-01-2008 18:37
(G) Spring Clamps supersei Panda (Classic) 3 04-06-2007 18:27
(T) exhaust clamps alanstalin Punto (Mk2/2b) 3 31-10-2006 17:01
