I rebulit my engine and put it all back in the car wired it all up and all when't good apart from a few littel problems. I Turned the key to start it and the engine turns over but would't fire after cheaking the for a spark there was none, i cheacked all the connections on the coil packs and all are dry and seem ok. I only replaced the coil packs about 1month ago there is no spark from eather pack so im gessing the problem is not the coil packs. I then thought it might be the TDC sensor so i whent to the local scrap yard and got another installed that and still no spark i know that the one i replaced it with could also be faulty but was told the car i had taken it off had been driven only a week ago, how true that is i don't know. Is there anythink anyone can think of to cheak becouse i have ran out of idea's ive also cheaked the fuse and thats ok also the earth's and all seem fine.
Many Thanks
Many Thanks
