Technical punto 2001 1.2 fault codes p0202 p0352 and u1601
dazza6969
please help
i have just purchased a fiat punto 1.2 mia 2001, and having running problems
car is only running on 2 cylinders and engine light is permanently on
i have a code reader and 3 fault codes have appeared
p0202 - injector circuit open cylinder 2
p0352 - ignition coil b primary/secondary circuit
u1601 - this says this is 'pending' and check manufacturer
does anyone know what could be causing this
i have replaced the plugs and leads and there is a spark to the leads
someone please help
