Styling Wheel spacers?
Josh Bowe
Member
Harrogate
Hey, just checked out Quinn Direct and they'll insure my car with alloy wheels on it so I've decided to fit my Dezent V Black wheels that are in my garage.
I was wondering though (I'm also going to be dropping the car 35/40mm) what wheel spacing would be best? Do I even need wheel spacing, if so what width and where should I go to get them?
Thanks.
PCD: 4x100 ET38
Not sure if they'll even fit a Punto but the site I bought them from said they would, if not I'm screwed! Not sure what J means and can't say I know what centre bore is either.
As you can probably tell, I don't really know much about cars. :p
The ideal offset of the MK2 is 33mm, so with 38ET you should be fine, but i would double check that they dont rub your arches. Also you will need wobbly bolts to fit as the PCD of most fiats is 4x98, but they can be picked up cheap on ebay :)
