FIAT Auto Specialist Team
Old 28-11-2008   #1
retro all the way!
jonboy739 has donated!
coil
are lasses sister has just been round cause her punto is not running right, i've traced it down to one of the coils not working and its only running on 2 cylinders, it still drives and turns over on its own but can only get 20mph out of it, its only just over 5 years old, is it common for them to go so quickly? or could it be something else on the wiring side that is not sending a current to the coil?
TIPO SEDICIVALVOLE
I'VE GOT A BIGGER ONE THAN
YOU UNO DRIVERS!!
TRANSPORTING CARS NOW
SO KEEP ME IN MIND
jonboy739 is offline Reply With Quote Quote
Old 28-11-2008   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: coil
Old 28-11-2008   #3
retro all the way!
Re: coil
Quote Originally Posted by T14086 View Post
cheers, i guess this is a common fault then, mine still has the original coil on and its nearly 17 years old.
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 29-11-2008   #4
retro all the way!
Re: coil
right i changed 1 of the coils and it still was the same so i've changed the coils around and found it is not the coil that is at fault and that it is not getting a signal from ignistion ecu, so i've got a second hand ecu from the scrap yard, but it wont fire at all now with the new ecu, are they coded or could it be a faulty ecu? i've put the original 1 back on and its firing on 2 cylinders again.
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 29-11-2008   #5
Trader Rating: 10
dave has donated!
Re: coil
they are coded
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 29-11-2008   #6
retro all the way!
Re: coil
is it expensive to get recoded, and is it main dealer only for recoding?
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 29-11-2008   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: coil
you didn't read the guide did you?
Old 29-11-2008   #8
Official Trader
Chris@souls's Avatar
Chris@souls has donated!
Re: coil
You can't use a 2nd hand unit! Once the phonic wheel learn procedure has been done the ECU's parameters are set to that car and it can't be used on another car!
Souls Motor Group - Please Contact Us For Your Parts & Accessories Requests.
See our Fiat Forum Traders Section: http://www.fiatforum.com/souls/
Chris@souls is offline Reply With Quote Quote
Old 29-11-2008   #9
Official Trader
Re: coil
You are welcome to send me the part number off the orig ECU and I'll get you a price!
Old 30-11-2008   #10
retro all the way!
Re: coil
yes i read the guide but i didn't have a test light or a power probe to test the ecu so i bought a new coil as from what i have been told they are common for going.
as for using second hand ecu Chris@souls would it work if i got the ignistion barrel and key from the car that the ecu came off and swapped them over? or is there over things that are coded up to the key?
i will get the part number for the ecu but will it cost alot? i gave £17 for ecu from the scrap yard which i thought was reasonable, if it had worked that is lol.
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 30-11-2008   #11
Trader Rating: 10
dave has donated!
Re: coil
no needs body computer too and car has to be exact speck of your car
Old 30-11-2008   #12
retro all the way!
Re: coil
so in other words these state of the art anty theft systems that they put on new cars are just a way of raping us of are money when they go wrong!
OLD FIATS
NEW FIATS
what is wrong with just putting a alarm imobiliser on so when your every day running parts mess up you can change them with little cost and you can do it yourself. damb all car companys for screwing us over.
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 30-11-2008   #13
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: coil
Quote Originally Posted by jonboy739 View Post
OLD FIATS
NEW FIATS
Because you wouldn't have a car because thieving gits would of stole it by now, thats why we have code 2 immobiliser systems so they cant be stolen and this is mostly due to the ECU! Also you wouldn't get the performance or fuel economy if you didn't have a ECU or the reliability and it also helps the car get through the EOBD emission laws.
In other words dont blame the manufactuer (all cars use this or similar systems) and get a new ECU (or at least get it tested at a garage) or a complete lock/key/ECU/body computer set at a scrapyard or ebay.
Old 30-11-2008   #14
Re: coil
New ecus are only about £120 anyway, so with what you have wasted on a used ecu and a coil you would have been a quarter of the way there. And you know that shop in Harry Enfields show Harry and Paul? I saw you coming? Thats your scrappy.
"Every day, in every way, I get better and better"
NumanR is offline Reply With Quote Quote
Old 30-11-2008   #15
Official Trader
Re: coil
£120 ?? hmm I'll take 10 off you then!! lol
Code 2 system is so more advanced compared to the old code one! Its one of the reasons why Fiats have low insurance groups!!
(T) which coil to get garsenior Stilo 30 05-12-2007 21:39
(T) Is it a coil or something more sinister? Dominion Stilo 6 17-01-2007 21:48
(T) New Coil Pack markyspark Punto (Mk2/2b) 2 03-06-2006 00:16
(G) what think of these coil overs?/ dave Punto (Mk2/2b) 41 17-10-2005 16:35
(T) coil testing Mick C Punto (Mk2/2b) 2 30-06-2003 22:23
