got code off ecu and looked at the new ones on ebay but none of them matched so i've phoned local fiat dealers and they have one and he said he will do it for £270 for me, is there anywhere i can look to get it cheaper?
am i best getting a diagnostic machine plugged up to it? it could be that the engine management light has been on for while but are lasses sister is that thick that she wouldn't of noticed it, no really she is thick enough lolunderlying problem yes, need to read the codes.
hi mate its orange, its the right ecu i think, i got it from ecutesting.com i gave them all the codes they needed to knowHi Jon, what colour is your engine light? If it is yellow, then the ecu should have flashed, if it is red this is not required. If you have fitted the wrong ecu the ecu will record an error, please let us know what colour the light is.
Hi Jon, its the wrong ecu, if you have a yellow light it would need to do a phonic wheel learn, (the revving three times whilst the yellow light flashes) if it didnt flash it wasnt the correct ecu OR it may have been a decoded one. BUT if it was a decoded one you wouldnt have a warning light on now unless there was a fault, and your old ecu would have picked that one up.
