i no nothing
- Nov 18, 2008
- 25
- 10
i have just changed both my rear wheel bearings & hit a problem,
1 side fitted perectly with no problems now the other side is a nightmare.
i have tried to fit the bearing & i cant get it to sit far enough back.
what i have done.
took off old bearing & washers.
put washer on, then bearing on
then washer on.
when i fit the disc it sits 2 far forward & hits the caliper bracket.
i have tried tightening the bearing to pull it further back but wont go back enough.
i have fitted this exactley the same way i did the otherside but cant work it out.
i had the same problem ages ago on another punto but cant remember how i solved it.
any ideas?
what i have done.
then washer on.
any ideas?
