![]() | #1 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | water leak in passenger footwell hi, was wondering if anybody has experienced a water leak in the passenger side footwell on a punto. the car is a Y reg. been in various garages who don't seem to know how to solve the problem. water only seems to leak when it's been raining hence a leak in a mechanical component can be ruled out. doesn't seem to be coming from the door either. last mechanic thought that it might have been leaves had clogged up the windscreen run off point which caused it to overflow but the runoffs are clear and it's still leaking any suggestions/advice would be grateful recieved.....i'm sick of it!!! cheers
![]() | #2 | ||
![]() | ![]() It may be leaking past the bulkhead at the top. What needs to be done is the bonnet and hinges to be removed off the car and silicone sealer needs to be applied at the back and sides where there are any gaps. Have done this a few times on mk 2's and seems to do the trick.
![]() | #3 |
Posts: 4,724 Thanks: 8 Trader Rating: 0 ![]() | Re: water leak in passenger footwell Welcome to the forum, just down the road from me then???!! Have you opened up the gromit just under the carpet near the glovebox (or have you got any additional ICE- needs the gromit for power lead) You could always go to Caledoina near Morrisons ![]()
__________________ BMW 123d M Sport Auto '10 Focus ST-3 Gone Hornet 600 K8 Sold ![]() Last edited by wolfracepunto; 13-09-2004 at 21:21. |
![]() | #4 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | Re: water leak in passenger footwell cheers for the responces, going to give the garage a bell who looked at it 2day and see if they have anymore ideas but failing that i'll go as suggested to fiat. was just a bit reluctant to let the main dealer have it because of the inevitable large bill!! and yeah i'm in bispham but work in st annes!
![]() | #5 |
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: water leak in passenger footwell whey, more local people! if you see a stupidly low yellow cinq.. thats me. or a yellow abarth kitted sei with blue mud flaps - don't race it, it belongs to my mate and has a 1242 in it!
__________________ .:: 1368cc 16v Cinquecento ::. |
![]() | #6 | ||
Join Date: May 2004 Location: Portsmouth, United Kingdom.
Posts: 136 Thanks: 1 Trader Rating: 0 | ![]() You have to attend to several areas on your car as mentioned previusly remove the bonnet and hinges and paint on a undersealant compound around the hinge area and across the bulkhead seams and the raise the car remove the front wheels and the plastic inner wing liner and again paint the seams visible this is the only way to attack the leaks and i would do both sides, also check that the door rubbers seal correctly.
![]() | #7 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: water leak in passenger footwell I have exactly the same problem on my W reg Punto, is there anything else I can look at? It's not coming in the door seal or the inside of the door, and two garages have failed to find the problem. How easy is it to remove the bonnet and hinges? Can I do it myself?
![]() | #8 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | ![]() Ok, have checked the door, bonnet hinges and the screen, all seem OK. It's coming down behind the black plastic moulded kickpanel - is this easy to remove? I've taken it to three garages now, no-one has found the solution and my local Fiat dealer says he won't look at it, I'm already £200 lighter and coming to the end of my tether!!!!
![]() | #9 |
Posts: 83,493 Thanks: 1480 Trader Rating: 10 ![]() | Re: water leak in passenger footwell ![]() Ok, have checked the door, bonnet hinges and the screen, all seem OK. It's coming down behind the black plastic moulded kickpanel - is this easy to remove? I've taken it to three garages now, no-one has found the solution and my local Fiat dealer says he won't look at it, I'm already £200 lighter and coming to the end of my tether!!!! ![]()
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #10 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: water leak in passenger footwell I can only remove the bolts, the actual hinges are spots welded to the engine bay ![]()
![]() | Morty Mort | Uno | 6 | 20-07-2004 19:20 |
![]() | Steven | Uno | 18 | 06-04-2004 04:57 |
![]() | edmoff | Punto (Mk2/2b) | 8 | 26-01-2004 22:32 |
![]() | aaajonathan | Cinquecento / Seicento | 20 | 24-08-2003 00:41 |
![]() | gavnotts | Tipo (Classic) | 1 | 14-03-2003 08:10 |
