jonnyburno
- Nov 4, 2008
- 5
- 1
basically i wrote of my 1984 mini and my mum gave me her fiat punto n reg 1.1 sx. after spending a few hundred quid on the mot i then found it had a pretty bad oil leak through the sump.
so i bought a 2nd hand sump which had a dent on the corner but no leaks and fitted it with a new oil filter and new oil. let the silicon set. then started it up up and it was running really lumpy and when i drove it found it had lost all its torque. the acceleration is shockingly poor and it struggles to get up hills. then i noticed it was still leaking slightly so took it off cleared some crud off the oil pick up looked like some of the silicon had fallen into the sump as i fitted it and then re fitted it and it still ran like like crap with the rough idle and rubbish performance. it struggles to get past 4000 revs unless you goin down hill
may be unrelated but sometimes is difficult to start just keeps turnin over and some times takes a couple turns of the key to start it
i've changed the lamda sensor, plugs and leads,
and am fed up with spending money on it but need to sort it as i do a lot of milleage and need to rely on it to get to work
any ideas would be greatly appreciated. other than the oil leak it was a brilliant runner before i changed the sump
