FIAT Auto Specialist Team
Thread Tools
Old 27-10-2008   #1
Question Flashing injection warning light
My daughters punto lost power but kept going on the way to work this morning. The injection warning light flashed on and off regularly. When she got to work she called the breakdown service to look at it. The problem had gone when they arrived. She drove home and all was well. It has just had new ignition coils (not Fiat parts) Any ideas - is it worth replacing all speed sensors as I have had problems with these on both Vauxhall corsa , VW polo
al68 is offline Reply With Quote Quote
Old 27-10-2008   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Flashing injection warning light
Flashing EM light is misfire or pre-catalyst damage, check plugs & leads first then look at the below link;
https://www.fiatforum.com/punto-guid...cu-checks.html
Old 27-10-2008   #3
Flashing EM light ? Engine Management I presume and this is the light that the handbook refers to as injection warning light, yes?
The coils are new and there has not been a problem since these were fitted a few weeks ago. ECU? the car is running fine now so it is an intermittent fault, does that rule out the ecu as a problem? It was a damp and cold morning and the problem had cleared up by 11.00am. perhaps I should look at the wiring. What is pre-catalyst damage?
Old 27-10-2008   #4
Polar Opposites
5abr3 has donated!
Pre catalyst damage is a failed exhaust to downpipe gasket or a hole in the manifold/downpipe.
My car pictures thread
Quote Originally Posted by TurboSei View Post
Anyway. Enough chatter, more arse action!
5abr3 is offline Reply With Quote Quote
Old 27-10-2008   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
As part of EOBD legislation the car must inform the driver (via EOBD/EM warning light) of emission control damage. If your car has a misfire then the cat will be contaminated with unburnt fuel which will ignite causing cat damage (renault cat's glow a lovely colour of red when a coil goes down, looks nice but costs the owner 600+) thus the cat will not be doing its job (preventing harmful emissions) as it is not operating within specification.
Old 27-10-2008   #6
I presume the onboard diagnostics computer will have identified a problem. How long will this hold the fault code since i will not be able to get it to a garage before Thursday?
thanks
Old 27-10-2008   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
It will still be logged (check plugs/leads first!)
Thanks al68 thanked for this post
Thread Tools
(G) airbag warning light and the injection warning light montysporting Punto (Mk2/2b) 3 17-06-2007 20:28
(T) EOBD warning light flashing Gunny Bedford Grande Punto 7 08-01-2007 21:58
(T) Flashing Warning light/ no idle Edward Dwightwell Cinquecento / Seicento 1 09-11-2006 12:47
