Technical antifreeze measurement
4.20 ltr but mix up 5.5 so you can bleed system proper
so you saying put 5.5 litres of water and antifreeze in or half of each to make 5.5
sorry for sounding thick but i have to make sure its right as its my mums car!!
im in a bit of a pickle ... ive just put 2lr of antifreeze in but it seems too much!... help?
Sounds like you have an airlock then, squeeze the top and bottom hose from the rad,(with the cap off) and the level should go down. If you got all of the old coolant out, then it should hold more than 2lts
Hope that helps,
Alan
cheers guys found my problem.... simple really ... a air block !!
because i took it for a run on the bypass and it was only blowing cold air so i parked up then 2 hours later gave the tubes a squeeze put some more coolant and water in took it for a spin again and blowing hot air again!!
so thanks for all your help :)
much appricated
glad you've got it sorted! I ended up parking mine nose up on the drive to sort my air-lock out, I'd keep an eye on it for a few days just to see if any more air-locks come out and to top up accordingly.
yeah there was another one that appeared so i topped it up a bit this morning after lols!.. im keeping an eye on it especally if i know im gonna go on the bypass! lol
