T Tommy1111 New member Joined Dec 23, 2007 Messages 4 Points 3 Location Staffordshire Oct 23, 2008 #1 Ive got a standard punto with normal steel rims on, is it it ok to put a set of abarth alloys using the same bolts as the normal wheels have?
Tris Harris Top Dog Parked in the garage Joined Jul 2, 2007 Messages 8,427 Points 1,128 Location Leeds/Whitley Oct 23, 2008 #2 Tommy1111 said: Ive got a standard punto with normal steel rims on, is it it ok to put a set of abarth alloys using the same bolts as the normal wheels have? Click to expand... personally, i'd get some locking wheel nuts, deters thieves and will help keep you new purchase safe.
S sid23456 Patron member Joined Jun 21, 2006 Messages 318 Points 62 Oct 23, 2008 #3 I needed longer wheel bolts going from steelies to abarth rims.
S smarty3108 New member Joined Oct 19, 2008 Messages 3 Points 1 Oct 25, 2008 #4 longer bolt on back were catching my brake shoes.
bbgames :) Joined Apr 20, 2008 Messages 56 Points 20 Location St. Helens Oct 26, 2008 #5 If this is for a Mk2 then I went from 14" steelies to 15" Abarth alloys. Used the same wheel studs as i did with the steelies and got some fiat locking wheel nuts. If its for a mk1, then I have no idea
