Old 20-10-2008   #1
mzhussein has donated!
Question heater niggle...
hi, small probelm, not serious realy, just a niggling thing that i thouhgt i could never fix.
but recently read something that sounded familiar to my problem.
basically, when i turn the heaters on setting 1 does nothing but settings 2 & 3 work fine.
i read somehting about resistors faulty??
can someone expand on this please?
thanks!!
(btw mk1 punto 60s-team 1999)
mzhussein is offline Reply With Quote Quote
Old 20-10-2008   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: heater niggle...
Hi mate,
Yes your right, its very common on the Mk1 for the resistor packs to go. The resistor packs basically limit the voltage that gets supplied to the fan, so when you put it on setting 1, it gets lower voltage than 2 or 3 (and so turns slower) when you select 2, the second resistor provides more voltage than 1 but less than 3, and the reason why 3 always works if the other resistors go, is becuase itsa just straight 12v and requires no resistor. You can get them out of a car at a scrappy for cheapness, or you can get them from fiat. They arnt that expensive. I always advise that you check the condition of your fan motor though, as the resistors normally go when its sticking or getting damp, so cure that first before replacing the resitor pack.
Hope that helps,
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 21-10-2008   #3
ace, will check them tomorrow, i erm like making things "different" would i be able to replace the burnt out resistance wire with a resistor of the same value? or another resistance wire, or does the whole unit have to be replaced.
from a bit of looking on the forum, im guessing that if i stick my head in the foot well and start undoing screws ill find it...
Old 21-10-2008   #4
Polar Opposites
5abr3 has donated!
Every one I've ever looked at has been either a moulded block with them in or a pain in the rear to open, faster to just change the whole block normally!
My car pictures thread
Quote Originally Posted by TurboSei View Post
Anyway. Enough chatter, more arse action!
5abr3 is offline Reply With Quote Quote
Old 21-10-2008   #5
oooh, ok, will have a poke and see what happens...
(T) No Heater Frostie Marea 7 26-07-2008 16:27
(T) My latest niggle luvduvs Grande Punto 20 30-06-2008 22:02
(T) heater or no heater dt900 Grande Punto 14 01-04-2008 22:43
(G) Help No Heater !!! magoosworld Ulysse 3 19-01-2007 15:30
(S) The only niggle I have with my Stilo's styling... James M Stilo 22 14-02-2004 18:59
