Old 20-10-2008   #1
Smile Brake Fluid Reservoir + Brake Fluid Question
Hi All,
In the brake fluid resevoir, the brake fluid seems to be just below the MIN mark, so I thought let me put a bit more in, so I unscrewed the cap at the top of the reservoir but noticed that the brake fluid reaches all the way up to the cap - is this normal? I also noticed that the 'neck' from the reservoir leading to the cap has a mesh type filter which I assume is to remove any crap from the brake fluid before it sips into the reservoir, could this be blocked? it all looks clean.
Any ideas?
oagra is offline Reply With Quote Quote
Old 20-10-2008   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: Brake Fluid Reservoir + Brake Fluid Question
Hi mate,
Yes sometimes that little mesh filter gets blocked. You can lift it out carefully with a screwdriver. BE CAREFULL - - break fluid is corrosive, and will strip your cars paint, or do you damage if you get it in your eye etc. Remove it and check its clean, then check the level. If its still too high, then you can use a pippet or similar to suck out the excess fluid unitll its down to the max line. You could also do this by bleading the breaks, but thats a bit more complicated.
Hope that helps,
Alan
Thanks oagra thanked for this post
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 21-10-2008   #3
Thanks Alan, wasnt aware that the little mesh could be removed, will try to remove it and clean it, thanks for the help!
(T) Brake Fluid Reservoir Replacement MikeSalt Punto (Mk2/2b) 7 23-07-2008 02:00
Another question re brake fluid Big Black Stilo Leisure Lounge 2 06-04-2007 22:35
(T) My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto (Mk2/2b) 5 02-04-2007 18:30
(T) Dot 5.1 Brake Fluid in Cinq Question SkinzCinqSporting Cinquecento / Seicento 22 07-11-2006 23:33
(T) Brake fluid question HornetUK Stilo 4 23-11-2005 21:32
