Hi
After leaving my car for a week it didnt start because of a dead battery, it has done this once before so i brought a new battery but it has still done it. After leaving it for the night and takes a few seconds to start up which means the battery is being drained by something. I have a amp in the car which is connected straight to the battery with a fuse in the wire and the speakers will occasionally stop working then start again when i move the fuse box on the wire around.
Does any one know if it would be that causing the power drainage or is there any other common parts that drain the battery if there is a fault that i could check.
