| Thread Tools |
![]() | #1 | ||
Posts: 99 Thanks: 0 Trader Rating: 0 ![]() | Broken plastic on key the plastic that is used to connect the key to key ring is broken, hence keeps falling off. should i just get a new key cut ? ... so that i have a key with a stable bit of plastic on it i cant afford to just carry the key round incase i lose it.
![]() | #2 |
Posts: 1,049 Thanks: 95 Trader Rating: 0 ![]() | Re: Broken plastic on key you will need to have the new key coded for the imobiliser to deactivate when you put it in the ignition. This depends on whather your car is a mk1 or a mk2, if its a mk1 the key cutters should be able to copy the code from your key. However if its a mk2 you cant get a coded key from a cutting place you have to go to fiat and pay around £100 for a new key. |
![]() | #3 | ||
![]() | Re: Broken plastic on key you can just drill a hole in the key to attach the keyring, just be sure to avoid the chip, mine has a hole in the top left of the key, quick fix till u can get a new key.
![]() | #4 | ||
Posts: 99 Thanks: 0 Trader Rating: 0 ![]() | Re: Broken plastic on key if i took it to a key cutting shop would they be able to just take off the existing plastic and replace it with a new bit of plastic ? cheers
![]() | #5 | ||
![]() | Re: Broken plastic on key dont think so.....well at least they couldnt for me. is it mk1 or mk2??
![]() | #6 | ||
![]() | #7 | ||
![]() | Re: Broken plastic on key its a mk1, that means a new key is only £20
![]() | #8 | ||
![]() | #9 | ||
![]() | Re: Broken plastic on key any good lock smith should be able to clone your blue key, ask around in your area, shouldn't take long to find a place.
![]() | #10 | ||
![]() | #11 | ||
![]() | Re: Broken plastic on key yes it does, would be advisable to tell em its chipped, but usually a clued up locksmith will know what ure talkin about. jst make sure u tell em its a mk1 cos mk2's are painful on the wallet to get a new key.
Thread Tools | |
![]() | Shelxs | Barchetta | 9 | 30-07-2008 09:48 |
![]() | jpholroyd | Stilo | 5 | 06-06-2008 18:05 |
![]() | can_u_hear_me | Punto (Mk2/2b) | 2 | 03-05-2007 22:23 |
![]() | winkle | Punto (Mk2/2b) | 9 | 28-08-2006 20:51 |
![]() | foster | Bravo / Brava | 6 | 30-05-2006 23:55 |
