Technical Reverse Lights won't Work
markwartd
Oldham, United Kingdom.
I've noticed that both my rear reverse light are not working I have changed both bulbs, but still no joy. i have also checked the connections between the bulb housings.
it's not too safe driving around without reverse lights, so i wanna get um fixed a.s.a.p.
Any suggestions would be appreciated.
Danny
(my car is a Mk1 Punto 1996 55sx)
Isn't the gearbox underneath the car? You know, directly below the gear linkages and the gear stick :D
gear box is found in the engine the gear stick is connected to it by linkages runing from under car to engine area. not exactly sure were the one is you looking for as dont have yoru car but open bonnet and look down either the left or more likely the right hand side of the engine bay. there will be a large metal mass low down inthe bay extending back towards the back of the engine bay area. you should see one little wire running towards it and stickin into the top of teh metal.
