Thread Tools
Old 18-08-2008   #1
maybe buying a punto 100 jtd 2001
Good morning people. Going to look at a punto 100 jtd today. Is there anything in particular that I should be looking out for fault wise. Any advice appreciated.
deezel57 is offline Reply With Quote Quote
Old 18-08-2008   #2
Belgium
Re: maybe buying a punto 100 jtd 2001
It will probably have the usual rattles from behind the dashboard. They are irritating but not constant or fatal.
Two biggest things to watch are the clutch and the power steering. If you engage the clutch the way it wants to be engaged, it will be fine. If not, you'll get some judders and shakes. Try adding a little more RPM before you release the pedal. If changing your technique doesn't solve it, expect to replace it. If the electric power steering goes out or doesn't work, that will be a fair pile of cash to replace. The steering may go out when driving but you can still drive the car. Well, sort of. Try stopping the engine and restarting it. That will work for a while but it's a strong signal that you need to take it Fiat pretty quick.
I would not mind having a diesel HGT as I think a little more grunt would be appreciated compared to the standard JTD model that I have now. Good Luck.
Oh, the Monkey Wrapped his Tail.
Around the Flag Pole.
To let the Wind Blow.
Up his Arse Hole!!!
raton_laveur is offline Reply With Quote Quote
Old 18-08-2008   #3
Thanks for your reply but the daughter decided against the car . advice appreciated
Thread Tools
(T) Help with bravo JTD 100 2001 engine swap!! please!! Stu Cook Bravo / Brava 22 23-01-2008 10:10
(G) 2001 punto jtd circ65 Punto (Mk2/2b) 11 15-01-2008 12:26
(G) 2001 Fiat Brava 1.9 JTD 100 ELX, how much would i get for it james-ace Bravo / Brava 12 10-08-2007 14:02
(G) 2001 Fiat Brava 1.9 JTD 100 ELX, how much would i get for it james-ace Bravo / Brava 2 07-08-2007 20:08
