Steve Selvage
This is what I meant, once the housing is tightened it seems stiff.He's probably talking about the gearbox itself.
Housings of the gearbox bolted together result with input shaft resistance. This could be a small misalignment, I mean some parts (bearings) are pressed into the shafts more or less deep, that's what's making the shaft harder to turn.
Unless it's a real mistake, significant f-up during assembly, it should fix itself the moment car is started and put into gear.
The small resistance to turn by hand can be actually desired, good thing (depends on the design, type of bearings etc.).
PS
Remember kids, don't start the engine without axles installed into gearbox. You can blow up the differential casing.
I didn't even check the first one I did before putting it in the car so just wondering if this is normal.
I've had it apart a couple of times and can't see any issues,I think it's time to put it back in the car and find out.
Many thanks for your replies
