![]() | #1 | ||
Posts: 3,213 Thanks: 267 Trader Rating: 0 ![]() | Brake Fluid Reservoir Replacement Guys, My girlfriend's mk2 1.2 Punto has an intermittent fault. The brake fluid level light flashes intermittently, but especially when cornering. The fluid level is fine, and we have disconnected the handbrake switch to eliminate that as the cause. That leaves the actual level sensor as a possible cause of the problem. When we unplug that, the intermittent fault goes away. I assume that the reservoir and level sensor are the same unit, that must be replaced. From what I can see, the reservoir is held on by two bolts at the top, and is connected to the car via three hoses and the clip to the sensor. Is there any special trick to replacing the reservoir? I assume that I can just disconnect the hoses, plug them up and then do the swap, filling the new one with fresh fluid. Am I likely to introduce any airlocks doing this? Many thanks, Mike
![]() | #2 |
![]() | Re: Brake Fluid Reservoir Replacement Exactly what level is the brake fluid at? Could be like petrol in the tank making the fuel light come on when you corner hard ![]() Jon.
__________________ Most Easterly Panda's - Panda'ing in East Anglia ![]() Stockest of mk2 Panda Parts, PM for any parts requests ![]() 1993 Classic Panda Selecta, 1989 Panda 750L, 2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG) ![]() |
![]() | #3 | ||
Posts: 3,213 Thanks: 267 Trader Rating: 0 ![]() | Re: Brake Fluid Reservoir Replacement Brake level is up to the 'MAX' marking in the reservoir, so it is definitely not the fluid level itself. The light comes on mainly when cornering, but also intermittently too. The local garage have said it is the sensor, but that it is not worth replacing. However, it will be worth replacing if I do it myself. Cheers, Mike
![]() | #4 | ||
![]() | Re: Brake Fluid Reservoir Replacement I would have thought you would be fine regarding airlocks. So long as air doesn't enter the brake or clutch cylinder (I.e. don't touch them at all during replacement) the only air will be in the filler pipes which should buble back up into the new reservoir when the fluid is topped up.
![]() | #5 | ||
Posts: 3,213 Thanks: 267 Trader Rating: 0 ![]() | Re: Brake Fluid Reservoir Replacement Xen, cheers for that. I thought so, but just wanted to be absolutely sure. Ebay time methinks....
![]() | #6 | ||
![]() | Re: Brake Fluid Reservoir Replacement Just be sure the clutch and brakes don't feel any softer before you drive off, otherwise they'll need bleeding (which isn't too difficult tbh.) but as i mentioned, i reckon you'll be fine. ![]()
![]() | #7 |
![]() | Re: Brake Fluid Reservoir Replacement Just get a new sensor from a scrappy. Is it one built into the cap/lid? Jon.
![]() | #8 | ||
![]() | Re: Brake Fluid Reservoir Replacement no it aint on the lid in a MK2, MK1s were though.
![]() | henk | Tipo (Classic) | 25 | 22-07-2007 17:13 |
![]() | keepinitcriss | Punto (Mk2/2b) | 5 | 02-04-2007 19:30 |
![]() | phoenix | Cinquecento / Seicento | 6 | 27-12-2006 11:07 |
