| Thread Tools |
![]() | #1 | ||
![]() | ![]() Hello, I just drove to work in my Punto 1.2 (5 million model, 2003, one of the last before they changed to the new style) and started smelling a hot, burning smell. I found this forum and it looks great, so wondered if anyone can help me..? I first noticed the smell when I had been driving about 20 minutes, when I slowed down/stopped at junctions. When I got to work about 10 minutes later I had a look and a sniff and there was nothing untoward under the car or anything. But under the bonnet I could smell the smell. It is like something is getting far too hot and sort-of burning. I don't think it's a plastic or oil burning smell and can't work out exactly what could be causing it. The smell is coming from the area above the oil filler, to the side of what I think is the air filter. I have checked the oil and it is low but still within the markers although I will top it up anyway. The water level looks fine. There is a little oil leaking out around the engine from a seal somewhere below the air filter bit but it doesn't smell down there. Can anyone help? I am a bit worried about what might happen when I drive home this evening... Many thanks, Rosemary
Last edited by rosemarydawn; 14-07-2008 at 10:59. Reason: Forgot to mention what car I have! | ||
![]() | #2 | ||
Posts: 3,213 Thanks: 267 Trader Rating: 0 ![]() | Re: Burning smell It is possible that oil is leaking over something hot, and causing the smell. I had the similar symptoms when my rocker-cover gasket was leaking. From what you describe though, it does not sound like the rocker-cover gasket, but perhaps an oil leak elsewhere.
![]() | #3 | ||
![]() | ![]() Thanks for your help Mike, Sorry to sound clueless, but what/where is the rocker-cover gasket? If it is an oil leak, do you think it would be safe to drive if I keep an eye on it or should I take it straight to a garage? Cheers, Rosemary p.s. I'll get around to introducing myself in the Newbie bit sometime soon!!
![]() | #4 | ||
Posts: 3,213 Thanks: 267 Trader Rating: 0 ![]() | Re: Burning smell Rocker Cover Gasket is the seal between the cover on the very top of the engine and the top of the cylinder head. The rocker cover is what covers the camshaft and rockers, hence its name. From what you describe, it sounds like the rocker cover gasket is too high up the engine to be the fault, so it is probably not this. If it is just oil, you should be alright as long as you keep it topped up. The flash-point of oil is much higher than the temperatures of the engine block, so oil fires should not be a problem. As with any burning smell though, get it checked out, just in case it is not the oil.
![]() | #5 |
![]() | Re: Burning smell Cheers! Can anyone recommend a good garage near Houghton Regis/Luton, Bedfordshire? There was a really good one that I used to go to but they've recently been taken over :-( Thanks, Rosemary
__________________ Rosemary ---------------------------- My other car is a Robin Hood! |
![]() | #6 | ||
Posts: 3,213 Thanks: 267 Trader Rating: 0 ![]() | Re: Burning smell I do not know the Luton area, but check out the good garage scheme rating... http://www.goodgaragescheme.co.uk/ Typically though, those on the scheme do tend to be a little more pricey.
![]() | #7 |
Posts: 1,520 Thanks: 130 Trader Rating: 0 ![]() | Re: Burning smell In your area Rosemary I'd recomend Autocraft Unit 9, Houghton Regis Trading Centre, Cemetery Rd, Houghton Regis, Dunstable, Bedfordshire LU5 5QH Tel: 01582 866688 Or We can help (Souls in Milton Keynes) if needed! ![]()
__________________ Souls Motor Group - Please Contact Us For Your Parts & Accessories Requests. See our Fiat Forum Traders Section: http://www.fiatforum.com/souls/ Last edited by Chris@souls; 14-07-2008 at 13:24. |
![]() | #8 | ||
Posts: 23 Thanks: 1 Trader Rating: 0 ![]() | Re: Burning smell Could be the breather pipe- it is a rubber pipe connected to the underneath of the air filter. They are known to perish, and let fumes out. Or the pipe might just be un-plugged as it is only a push fit to the air filter box. If it is this, the smell will get worse with the ventilation fan on. Hope it's this because it's a dead simple, 5 minute job to replace, and the couple of inches of rubber pipe can hardly be expensive to buy. If the pipe is perished, you'll see oil on it. You can see this pipe by removing the air filter box (two screws and a spring clip). John
![]() | #9 | ||
Posts: 284 Thanks: 20 Trader Rating: 0 ![]() | Re: Burning smell Check exhaust pipe as it's possible that you run over plastic bag and it glued itself to hot exhaust. This often happens and it smells like you described.
Thread Tools | |
![]() | devon_guy | 500 | 22 | 10-06-2008 20:15 |
![]() | alone_withmyaxe | Panda | 12 | 08-04-2008 09:37 |
![]() | luvduvs | Grande Punto | 35 | 10-12-2007 07:53 |
![]() | dilpz213 | Cinquecento / Seicento | 2 | 08-04-2007 23:09 |
![]() | dave doyle | Punto (Mk2/2b) | 1 | 20-07-2006 15:42 |
