Thread Tools
Old 20-06-2008   #1
Question Electric Window (Drivers Side) not working
On my 5dr punto mk1, my drivers side electric window doesn't work. When you press it, the eletric motor whirrs, but the window doesn't move. The passenger's side electric window works fine (when pressed either side). The rear windows are manual.
How easy is it to get into the door to have a look? I have no idea where to start. How easy do you think it'd be to fix? Would I have to buy a new motor/mechanism? How much do they cost & where from?
Any help is greatly, greatly appreciated!
Colin
Colin. is offline Reply With Quote Quote
Old 21-06-2008   #2
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
Re: Electric Window (Drivers Side) not working
getting into the door is easy and the mechanism and motor are all one thing so that's what you'll need to by before you even look
i just got a manual one for about 20 quid from fiat so maybe electric somewhere near 50 60 or so
you undo all the screws and allen keys thou the handle
and pull the door card away being careful not to rip the push clips out of it they will click as they come off there mating clip on the door
then lift the door card up to release the seal from the top
then using a Stanley blade carefully cut the weather sheet away from the door cutting along the glue line in such a way as it can be re atached to the door and not leak in water
then under this is the regulator held in with 4 10mm bolts
2 for the motor
2 for the mechanism
to remove the mechanism from the glass yu need to pull out a plastic c clip
when fitting the new window regulator firs wind it fully down after it is loosely in place and attached to the window then tighten the bottom bolt
ten wind it up fully and tighten the top bolt
that way it will align the mechanism for you making the window work much smoover and faster
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 21-06-2008   #3
Okay thanks a lot! I'll have a look inside
Thread Tools
(G) Help! drivers electric window stuck wringerbay Bravo / Brava 4 27-05-2008 23:29
(T) electric window not working leaky Punto (Mk2/2b) 1 07-09-2007 09:38
(G) Moody drivers side electric window panda type thingy Punto (Mk2/2b) 2 11-02-2007 23:49
(T) Drivers Electric Window Problem Superboy Grande Punto 7 29-11-2006 02:03
(T) Electric N/S window not working jep73 Bravo / Brava 5 21-09-2006 22:54
