D doidge0 New member Joined Apr 23, 2008 Messages 37 Points 25 May 31, 2008 #1 Hello, my freind noticed on my mk1 punto today that the rear wheels look like they have a slight negative camber angle like \ / exept not as dramatic, it only looks ever so slight but is this normal on this car ? Thanks
The Sultan Bravo 1.8 HLX FTW Written 5 guides Joined Jul 28, 2006 Messages 4,217 Points 736 Location lake windermere east edge May 31, 2008 #2 the body work on cars makes them look like this youl probably find it closer to straight up and down park on level ground and use a small spirit level on both wheels but there's nothing that could fail to make the wheels sit like that unnaturally nor is there any adjustment so i would worry about it it's normal
D4nny8oy Established member Joined Apr 6, 2007 Messages 2,883 Points 433 Location Yep, still here. Jun 1, 2008 #3 Negative camber is when the tops of the wheels are closer together- more like / \. Knackered radius arms or wheels bearings could cause excessive camber changes, but you'd notice the knocking/rumbling noises if they were that bad.
The Sultan Bravo 1.8 HLX FTW Written 5 guides Joined Jul 28, 2006 Messages 4,217 Points 736 Location lake windermere east edge Jun 1, 2008 #4 D4nny8oy said: Negative camber is when the tops of the wheels are closer together- more like / . Knackered radius arms or wheels bearings could cause excessive camber changes, but you'd notice the knocking/rumbling noises if they were that bad. Click to expand... that's correct actually but he knows what he meant to mean if you know what i mean
