Hi Punto gurus,
I have problem with Punto 55 1996. The cylinder 2 does not get spark at all. I changed the spark plugs. It didn't help. I tested the HT lead of cylinder 2 by plugging it into the ignition coil which gives voltage to the cylinder 1 and plugging old spark plug into the spark plug end of the HT lead. Then I checked that the spark plug gave good sparks when starting. So the problem is not in the HT lead of the cylinder 2. Have you had same kind of problems. If yes, had it be problem with the ignition coil or problem in the ECU or something else? Thanks in advance.
- Jorma
- Jorma
