Car is idling too high after a head gasket change.When you start it from cold it revs really high(which cant be good for a cold motor)for a second or two then settles a bit.When car is warm it idles way higher than it used to.I've checked all things that could have been disturbed when the head work was done but i've drawn a blank.It's now using way more fuel than before gasket change.For quite a while now the Catalytic converter section of the exhaust has been blowing a little,maybe this has been made worse by the manifold coming off?I'm going to replace it anyway,is there a lambda sensor on these?
