Technical Misfiring Punto 1.2 16v
ben_zulu83
United Kingdom.
I have had a misfiring problem with my car now for about 6 months. Fiat have changed coil pack, an injector, spark plug and leads. They have also tried a new ecu, didnt fix it.
Can anyone help????!!
The problem, bumpy idling and lack of power when accelarating.
welcome to the forum:)
is it all the time or just when its warm
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
smooth binki, digging binki, waiting for headrub binki, running binki,
Does it sound like it's only running on 3 cylinders? If they've checked all the ignition and electrical side, perhaps it could be the fuelling system that is at fault.
Is it knocking when the engine is warm?
Oh yeah, have you done a compression test?
________________
1999 Red Punto 60S, wannabe sporting.
Hey i have the exact same issue with my puno 1.2 16v coil changed ecu etc etc, missing when engine is warm, any ideas would greatly be appreciated check my thread to same problems but my ecu light is off..
2 comments
1 - this thread is 9 years old, the OP probably doesnt come here
2 - Stick to 1 topic, dont keep dropping in others
I'll post in YOUR topic :)
Ziggy
Hey man I had the same problem with my car and like that lad from 2004 replaced all he did, turned out to be low on compression on cylinders 2 and 3
Can someone please change title of thread to
"the thread that will not die"
Or "zombie thread Of doom"
It died then was resurrected 9 years later.
It died again then came back to life after another 7 years
Haha I agree this tread needs to end but before it does, I need to say that it wasn’t the head gasket it was the previous owner had let the car run low on oil thus scoring the cylinder wall and fecking up the engine....and then I bought it [emoji23][emoji23].Currently the car is long term storage and I’ve a 2002 broom yellow one. Right that’s the last post in this. Goodbye
