Old 28-04-2008   #1
Malta
Mk 1 punto interior light
I wanted to change my interior light in my punto sx mk1 98 because the previous owner changed it to a blue colour and its quite dim and cant see anything really with it. I cant figure out how to take it off exactly. Maybe to help a bit the light is the one which has the clock under it instead of having it next to the speedometer in the dash.
Robot666 is offline Reply With Quote Quote
Old 28-04-2008   #2
lizardlace has donated!
Bat Punch Champion
Re: Mk 1 punto interior light
i need to change mine too, cause mines too dim
Breaking Punto Sporting
lizardlace is offline Reply With Quote Quote
Old 28-04-2008   #3
If you look there is a joint in the plastic (not the clear part). If you put a flat screw driver in the small gap which is one side it will unclip.
darrenl is offline Reply With Quote Quote
Old 28-04-2008   #4
Malta
Cant find the part you are mentioning but I checked the car in daylight and found like 4 plastic covers that come off and have screws under them. Didnt have a screwdriver on me at the time but later on ill give it a try. Just in case what kind of bulb/led will fit in the interior light? Thanks
Old 31-01-2009   #5
yep there's four small covers in each corner of the block where the interior light, clock, map light is. just get a knife or screwdriver and pop them out, then there's four screws to undo then the whole unit just comes down, lift up the back cover and take the bulb out! seemed so simple after i done it! Cheers all for help XD
Thanks Tonesav thanked for this post
AaRoNdAe is offline Reply With Quote Quote
(T) Punto Interior Light, Radio and Fuses tomweise Punto (Mk2/2b) 11 10-11-2018 10:05
(G) Interior light/Map light assembly removal Blood Junkie Stilo 4 08-02-2008 23:07
(T) punto mk2 interior light sunny2539 Punto (Mk2/2b) 5 19-04-2007 14:50
(G) Mk2 Interior light (Fiat Punto 1.2 2001) fahema Punto (Mk2/2b) 2 10-01-2007 00:33
(T) Punto MK2, interior light? Maranello Punto (Mk2/2b) 4 25-09-2003 14:50
