Old 16-04-2008   #1
Punto Management Light On. Other Warning Lights Stay On When Ignition Turned Off.
Hi, Have a problem with a 2001 Punto 16v. The management light has been staying on. Had codes read which suggested "Lambda" sensor's or cat.converter. Have changed Lambdas, reset codes, but the light is back on. Have looked at base of cat. converter (inside) and there is no flakey material, does this mean that the cat. converter is O.K? or am i trying very hard not to spend money on a new cat. Further to the management light staying on, occasionally other warning lights stay on when the ignition is turned off. The only way to clear this is to switch the ignition on and off a few times. Each time i switch off, i get a different combination of warning lights staying on, until eventually they all go off! Any advice appreciated.
Mike. is offline Reply With Quote Quote
Old 17-04-2008   #2
Banned
Oldschool has donated!
Re: Punto Management Light On. Other Warning Lights Stay On When Ignition Turned Off.
It should not be related to the cat. Try disconnecting the battery for a while, which sometimes helps. It is a known problem with some of the Puntos.
Thanks Mike. thanked for this post
Oldschool is offline Reply With Quote Quote
Old 17-04-2008   #3
This can also be caused by a bad connection on the earth strap from the gearbox to the body. HTH.
DoIDon'tI is offline Reply With Quote Quote
Old 18-04-2008   #4
Not sure about the EML but have seen problems with other warning lights staying on after ignition off. I believe it is poor connections in the multiway plug/socket at the rear of the instrument cluster.
Good luck!
percy is offline Reply With Quote Quote
Old 19-04-2008   #5
HI, Thanks for all the advice. I did disconnect the battery for an hour, seems to have cured the warning lights staying on after ignition turned off problem. Can i ask OLDSCHOOL re his advice, does he think that the Engine Management Light being on and the code telling me its Lambda or Cat. is wrong? I am trying to avoid replaceing the cat. as its a "Maneverter" and expensive.
Question 2. I have seen code readers on e-bay for 60 ish, are these any good, and where is the code reader socket on a 2001 16v Punto ELX?
Thanks for the advice.
Great forum.
(T) Engine Management Warning Light Madness! Power Steering light Insanity! Moneypenny Punto (Mk2/2b) 11 12-02-2010 14:10
(T) Engine Management Light/Temp Warning Light Fault bugalugz Punto (Mk2/2b) 1 09-01-2009 23:52
(G) warning lights on when ignition off!? bloody car Punto (Mk2/2b) 14 15-12-2008 12:23
(T) Bravo 1.2 engine management warning light LeeP Bravo / Brava 1 27-02-2008 14:37
(T) Engine Management Warning Light urbantiger Punto (Mk2/2b) 0 03-12-2005 01:28
