Hi, Have a problem with a 2001 Punto 16v. The management light has been staying on. Had codes read which suggested "Lambda" sensor's or cat.converter. Have changed Lambdas, reset codes, but the light is back on. Have looked at base of cat. converter (inside) and there is no flakey material, does this mean that the cat. converter is O.K? or am i trying very hard not to spend money on a new cat. Further to the management light staying on, occasionally other warning lights stay on when the ignition is turned off. The only way to clear this is to switch the ignition on and off a few times. Each time i switch off, i get a different combination of warning lights staying on, until eventually they all go off! Any advice appreciated.
