im Axle Specialists
Thread Tools
Old 15-04-2008   #1
help
any one know if a 04 punto engine would fit in a 2000 punto. stick lnform me if your on here or anyone else.
anth is offline Reply With Quote Quote
Old 15-04-2008   #2
Romania
Re: help
i think mk2 04 8v 16v equals 00 8v 16v difference is mpi spi, but i am not a pro
Raducu is offline Reply With Quote Quote
Old 15-04-2008   #3
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
Re: help
Quote Originally Posted by Raducu View Post
not quite
the only difference is emissions regulations at the time
meaning the size and shape of the ports are different n the head
both engines have mpi but the 00 have grouped the 04 have sequential
and finally 0 has crank sensor only 04 has crank and cam or phase sensor
no mk2s have spi only mk1 i'm afraid
the engine it's self will both run fine with each others ecus but but you will have to swap some covers and cam pulleys for the extra phase sensor
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 16-04-2008   #4
Re: help
and wat covers may these be may i ask rocker,inlet outlet
Old 16-04-2008   #5
Bravo 1.8 HLX FTW
The Sultan's Avatar
Re: help
Quote Originally Posted by anth View Post
yes rocker cover for the sensor
the inlets would have to stay with the engine but either throttle body could be bolted to them and injectors could be swapped as they are different
i asume exhaust manifold will have changed too just need to have a look at some really and see if there is any difference in the shape of the ports
Old 17-04-2008   #6
Re: help
am sorted cheers
Thread Tools
