Technical Worth fitting K&N Air Filter?
Well it looks like I'm not going to buy anything to 'mod' this car. I'm saving up to buy a different make of car, maybe a Corsa or Clio or some other small hatchback.
I won't be buying one for quite some time though as I can't afford it :cry:
I'll be trading this car in. God knows how much I'll get for it as I have had an accident. I scraped the paint and damaged the rear passenger door. I also have a deep scratch on the drivers side wheel arch, I don't know how this got here!! Maybe I could fix them (but not the damage).
Looks like I'm not going to buy another car after all!!!!
Might get it resprayed and the dent knocked out. :)
Is the Focus Induction kit only for FIRE engines?
Could it fit a (normal) 1.2 8v engine?
If not, why won't it fit?
You can't fit the focus kit on the 16v. If you want to, you will have to modify it to make it fit. AND you will be the first one to do so, hence not much advice on this subject. Personally i dont think you will be able to make it fit as the pipe that comes with it bends at an angle in two places.
ok then mate, when it comes i'll check out what needs doing to it and see if I can get it done, thanks for getting back to me though ;)
